Dynamic component PointCloudFilter
  • Apr 4, 2019 7:55 AM UTC
  • 74 views
txalaparta
Forum|alt.badge.img+3
Hi all
I´m working with a point cloud with the following schema
x|y|gridnum|col0|col1|col2|.....|colN
10|22|121212|12|23|.....|234
10|22|121212|0|12|.....|234
The number of components will vary and I can´t tell a fixed number
As output I want to remove the 0 values from the col(x) components
10|22|121212||12|.....|234
I´m using an iterator to go through all the components
Using PointCloudFilter I´m achieving it but only with fixed components.
I can also use a user parameter to set component. But again, I cannot update modify.
As I cannot use attributes in PointCloudFilter, Is there any way to update the value of the user parameter dynamically within the workspace? I´ve also considered JobSubmitter but I don´t have FME Server....
I think that an iterator is needed because I can´t say in advance how many components I will have.
Thanks so much in advance
itay
Forum|alt.badge.img+19
  • Apr 4, 2019 9:52 AM UTC
Hi @txalaparta,
Have you tried the RasterCellCoercer (Output Cell Geometry = Points) with Extract Nodata Values set to no?
Hope this helps,
Itay
txalaparta
  • Apr 4, 2019 10:18 AM UTC
Hi Itay
Thanks for the quick replay.
In this case the points come from already "cleaned" rasters. So, there shouldn´t be any NoData points.
This case is all about reformating the output. I did it first reading each point in the point cloud and then with a StringReplacer but it takes forever comparing to PointCloud transformers available in FME
Correct me if I didn´t understand what you meant.
Thanks again anyway.
