draw lines between points
nath
Hi
I have to draw lines between two points with different attributes. They have a common number but in another field.
All point have to be connected with a line to the network
I have already made a table with the coordinates of the beginpoint and the endpoint in the same record.
As the endresult i have to become lines with a unique Id and the attributes of the point where the ID starts with HP_.
Can sombody help me please?
Thx!
Nathalie
pratap
Forum|alt.badge.img+11
  • March 30, 2016
Unable to understand the requirement. Is it possible to explain with screenshots and provide sample data?
  • March 30, 2016
Hi @nath, since you already have a table containing coordinates of two points per a record, you can read the table and then create line segments for each record using two VertexCreators in a series.
  1. Create the beginning point with the 1st VertexCreator.
  2. Add the ending point with the 2nd VertexCreator (Mode: Add Point).
Regarding ID, I think you can use the StringConcatenator or AttributeCreator to concatenate multiple strings including literals and attribute values.
nath
  • March 30, 2016
zcartografiewerkmappenaalstnathalie2016knipsel.jpg zcartografiewerkmappenaalstnathalie2016knipsel2.jpgIn this example there needs to be al line between HP_341 and 110799444759_1
pratap
  • March 30, 2016
If you do not receive with the method of @takashi suggested then add geometryremover before vertexcreator and recreate the line.
nath
  • March 30, 2016
It works! :-)
Thanks
