"directory and file path names" - source folder
  • Jun 8, 2018 10:09 PM UTC
  • 431 views
Hello,
I am at very early stages of incorporating FME into my work, and I am trying to figure out how to unzip all zip files in a folder (and all zip files in subfolders).
I was able to unzip files with the "directory and file path names" transformer (**/*.zip) by passing folder and file locations to ZipExtractor. However, That transformer asks me to provide a "source folder" before it can start running. Is there a way to define the source folder to the folder of my .fmw file?
I plan to use this same file with different folders and I would like users to be able to copy the .fmw file into another folder and run it there without providing a source folder location everytime.
Thanks!
  • Jun 9, 2018 1:24 AM UTC
A built-in parameter called "FME_MF_DIR" stores the directory path to which the workspace file (*.fmw) is saved. I think you can set $(FME_MF_DIR) to the source folder parameter in the Directory and File Pathnames Reader.
  • Jun 9, 2018 1:26 AM UTC
The transformer wouldn’t accept that variable as source folder unfortunately. Is there a way around it?
  • Jun 9, 2018 1:51 AM UTC
I assume that you are using the Director and File Pathnames reader (not a transformer), and I believe that it works fine to read every zip file path under the FME_MF_DIR, including its subfolders. Make sure that the reader parameters have been configured correctly.
  • Jun 11, 2018 9:58 PM UTC
Thanks! I was able to set the source folder to FME_MF_DIR from the navigator, I also moved it to private parameters so it wouldn't prompt to user.
