Difference in Oracle non-spatial reader and a joiner
  • Dec 19, 2012 9:16 AM UTC
  • 75 views
I have problem with the joiner-transformer. When joining tables from an Oracle database all unicode characters are not handled correct. Ex æøåÆØÅ.
But if I create another reader-import-type with the same table it handles the unicode characters correct.
Is there a setting on the joiner-transformer that i have missed? Or is it a bug?
(I'm using fme 2012SP4 right now but the problem was also present the previous version I used. I think it was v2010.)
/Tim
sigtill
Forum|alt.badge.img+25
  • Dec 19, 2012 11:07 AM UTC
Some fixes done related to Oracle and Joiners in 2013 atleast:
http://downloads.safe.com/fme/beta/whatsnew.txt
fmelizard
Forum|alt.badge.img+22
  • Dec 20, 2012 11:16 AM UTC
Hi folks,
I  tested this in FME 2013 (Build 13250) and I can see the issue Tim described still there.  I would have thought the fixes SigTill pointed to would have resolved this but apparently not.  I will escalate this to a support case so we can track the issue.
Looks like you are aware of this but for the sake of others,  if you add the table with a reader and use the FeatureMerger transformer you can get around the issue.
Thanks for reporting this Tim - it really helps us when people take the time to tell us about issues,
Ken
