DGN reader - drop complex shapes
  • Apr 4, 2019 11:40 AM UTC
  • 83 views
Forum|alt.badge.img+54
If using the DGNV8 reader and choosing to Drop Complex Chains/Shapes is there any common attribute between features that originated from the same complex shape?
daveatsafe
Forum|alt.badge.img+24
  • Apr 8, 2019 11:54 PM UTC
Hi @egomm,
The component lines from each chain will have a common value for the igds_chain_number attribute.
  • Apr 10, 2019 1:14 PM UTC
Hi @egomm,
That doesn't appear to be the case for the feature I'm investigating - drop complex chains/shapes appears to split a single feature into many features but there are two different chain numbers amongst the output. I can't even find the feature in microstation so hard to say how it's actually made up.
daveatsafe
  • Apr 10, 2019 8:03 PM UTC
Hi @egomm,
If you would like to send me the Microstation file, I would be happy to have a look at it. You can send it to me directly at .
  • Apr 11, 2019 4:34 PM UTC
Hi @egomm,
I can't share it unfortunately
