Design file working units
  • June 28, 2016
  • 10 views
itay
Forum|alt.badge.img+17
Hi all,
I was wondering if there is a way to influence the creation of DWG files, without the use of a template file, so that it would be displayed in meters as working units in Microstation?
erik_jan
Forum|alt.badge.img+19
  • June 28, 2016
Itay,
What do you mean: DWG is AutoCAD and can use a template.
MicroStation is using DGN and the units are defined in the required Seed file.
