Data upload via REST makes the dbf of my shapefile corrupt
  • Oct 22, 2018 11:32 AM UTC
  • 10 replies
  • 133 views
jeroen
Forum|alt.badge.img+15
Using FME Server build 18305
I am testing the Upload multiple files in the FME Server REST API V3 on my server.
The goal is to upload a shape file using the POST /resources/connections/< resource >/filesys/< path > (Upload multiple files) method but getting stuck on using the file due to corruption.
These are the settings:
The return looks like this:
Response Code:
200
Response Body
    "date": "2018-10-22T11:09:43Z",
    "path": "/Testwerk/",
    "size": 8360,
    "name": "waterschapsgrenzen.dbf",
    "type": "FILE"
    "size": 428,
    "name": "waterschapsgrenzen.prj",
    "type": "FILE"
    "size": 170,
    "name": "waterschapsgrenzen.shx",
    "type": "FILE"
    "size": 960243,
    "name": "waterschapsgrenzen.shp",
    "type": "FILE"
Everything looks OK till now, but when downloading and inspecting the shapes with the Data Inspector or useing it in flow the following error with the dbf pops up:
Log File: C:\Users\jeroen\AppData\Local\Temp\FMEDataInspector\logs\fmedatainspector_2018-10-22T13-21-08.log
Loaded module 'fmeprompter' from file 'fmeprompter.dll'
'ESRISHAPE' reader was created successfully
Creating reader for format: Esri Shapefile
The dataset 'C:\Users\jeroen\Downloads\waterschapsgrenzen.shp' was opened successfully
The feature cache has not been loaded while a new setConstraints was performed. Now loading...
Using Shape Reader to read shape files from folder `C:\Users\jeroen\Downloads/'
R_1 Reader: Using enhanced geometry
Shape Reader: Using simple donut geometry detection
Shape Reader: Handling numeric types with standard integer and floating point types
Shape Reader: Allowing attribute names with mixed case
Opened Shape File 'C:\Users\jeroen\Downloads\waterschapsgrenzen.shp' for input
Opened DBF File 'C:\Users\jeroen\Downloads\waterschapsgrenzen.dbf' for input
DBF Reader: Could not detect encoding. Using default system encoding
DBF File 'C:\Users\jeroen\Downloads\waterschapsgrenzen.dbf' has fields: A DBF Internal Type Designation '
The OGC definition of the FME coordinate system '_Netherlands-RDNew-2008_0' is 'PROJCS["RD_New",GEOGCS["GCS_Amersfoort",DATUM["D_Amersfoort",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Double_Stereographic"],PARAMETER["False_Easting",155000.0],PARAMETER["False_Northing",463000.0],PARAMETER["Central_Meridian",5.38763888888889],PARAMETER["Scale_Factor",0.9999079],PARAMETER["Latitude_Of_Origin",52.15616055555555],UNIT["Meter",1.0]]'
FME Configuration: Source coordinate system for reader R_1[ESRISHAPE] set to `_Netherlands-RDNew-2008_0' as read from input data
Coordinate System `_Netherlands-RDNew-2008_0' parameters: CS_NAME=`_Netherlands-RDNew-2008_0' DESC_NM=`Netherlands, Amersfoort RD 2008 datum, New System' DT_NAME=`Amersfoort-RD-2008' ESRI_WKT=`PROJCS["RD_New",GEOGCS["GCS_Amersfoort",DATUM["D_Amersfoort",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Double_Stereographic"],PARAMETER["False_Easting",155000.0],PARAMETER["False_Northing",463000.0],PARAMETER["Central_Meridian",5.38763888888889],PARAMETER["Scale_Factor",0.9999079],PARAMETER["Latitude_Of_Origin",52.15616055555555],UNIT["Meter",1.0]]' GROUP=`EUROPE' MAP_SCL=`1' ORG_LAT=`52.15616055555556' ORG_LNG=`5.387638888888889' PROJ=`OSTERO' QUAD=`1' SCL_RED=`0.9999079' SOURCE=`Kadaster' UNIT=`METER' X_OFF=`155000' Y_OFF=`463000'
No shape record found when reading record number '1'.  Shape file is either corrupt or end of file has reached with no meaningful data
Unable to input data from file 'C:\Users\jeroen\Downloads\waterschapsgrenzen.dbf'
Failed to specify the feature index as constraints on the reader
No shape record found when reading record number '2'.  Shape file is either corrupt or end of file has reached with no meaningful data
Removing dataset 'waterschapsgrenzen [ESRISHAPE]' from View 1
The dataset 'C:\Users\jeroen\Downloads\waterschapsgrenzen.shp' was closed successfully
The 'ESRISHAPE' reader was destroyed successfully
Is there a way to fix this?
I also saw that the .dbf file has a file size of 8.36KB when uploaded by REST and 8.34KB when i upload it myself using the upload functionality in the Resources folder. Also the other files are larger after uploading.
  • Oct 22, 2018 11:57 AM UTC
I quickly tried using the same endpoint to upload your "temp.zip" file to FME Server 2018.1 and could reproduce the exact same behavior.
Since uploading through the server GUI works without a problem, I'm wondering if Swagger (the tool that's used to generate the interactive API documentation) hasn't been properly set up for this endpoint.
One main difference is that the Content-Type header differs when using the API doc and the GUI:
API documentationFME Server GUIContent-Type
multipart/form-data
application/octet-stream
Have you tried doing resource upload with some other tool, e.g. Postman?
jeroen
  • Oct 22, 2018 12:06 PM UTC
multipart/form-data
I have tried to do it with postman but getting stuck on Status 500 Internal Server Error
    "message": "An unhandled exception has occurred due to some unexpectedly omitted information, consult the web service logs for further details"}
Or  Status: 415 Unsupported Media Type when using another Content-Type.
I cannot find the log they mention so i do not have any information with that
  • Oct 22, 2018 12:18 PM UTC
I tested uploading a file using Postman with the following configuration:
for the body I specified the follwing:
Downloading the file from the FME Server GUI i got the exact same file and could open it in Data Inspector with no issues.
I think this confirms my suspicion about the API docs having an issue with this endpoint.
jeroen
  • Oct 22, 2018 12:22 PM UTC
multipart/form-data
Using the application/octet-stream status 422 Unprocessable Entity (WebDAV) (RFC 4918) is returned
jeroen
  • Oct 22, 2018 12:37 PM UTC
I'm getting the following result using a Temp.zip file:
  • Oct 22, 2018 12:41 PM UTC
Seems like you forgot to specify the body contents as well as the headers?
jeroen
This works, but how can i use it for multiple files?
  • Oct 22, 2018 12:59 PM UTC
Any particular reason for not simply iterating over each file and upload them individually? Personally, I would recommend that.
jeroen
  • Oct 22, 2018 1:38 PM UTC
I prefer to upload all files at once, per job and keep unnecessary loops out of the code.
  • Oct 22, 2018 1:56 PM UTC
Unfortunately I don't have an example for uploading multiple files, but maybe Google (or someone else here) can help... For example, this might help: https://stackoverflow.com/a/26791188
