CSV reader not able to read from network drive
  • Jun 27, 2018 9:13 AM UTC
  • 73 views
The workspace works in workbench. I am just reading a csv file from a network drive and doing some transformation and outputting another csv file back into the network drive.
However when I publish it into fme server and run from there, I received an error
"CSV Reader: Failed to read the specified file(s) in the folder '\\\\xxxxxxxxxxxxxxx.csv'"
Anyone has any idea?
Inside workbench, the destination csv contains the hardcoded network directory.
Thanks
Forum|alt.badge.img+63
Does FME Server have access to that folder? (to be specific: the user account under which FME Server needs to have access to that folder).
Hi sorry how do I check? From FME server? Sorry Im not very technical.
  • Jun 27, 2018 9:49 AM UTC
You will most probably have to configure the FME Server engine service to run as a domain user, see:
http://docs.safe.com/fme/2018.1/html/FME_Server_Documentation/Content/AdminGuide/Running_System_Services_Under_Different_Accounts.htm
The default local system account has no access to network resources.
