Creating points from lat/long fields
  • November 24, 2015
  • 1357 views
Usually I would use arcmap to displayXY (to draw the points from the lat/long fields) and then publish to AGOL, Can I do this in FME ?
Forum|alt.badge.img+49
Yes, you can use the VertexCreator to create points out of no-geometry data with attributes holding x, y (and z) coordinate values, then write out to AGOL.
