Creating metadata in zipped file geodatabase
  • Jun 26, 2014 3:41 AM UTC
  • 0 replies
  • 33 views
I have a workbench set up where I create a Feature Class inside a file geodatabase. the next step is to create the metadata and load it into the same Feature Class. This all works fine.
I'm doing the exact same thing with a zipped file geodatabase and it's giving me errors.
 Attempting to create table 'XXXXXXX' with 'geodb_type' set to 'geodb_metadata'. FME features of 'geodb_metadata' can only be written to existing tables. If intending to write metadata, please ensure the table already exists.  If intending to create a new table, ensure the 'geodb_type' is set to a valid table type. A fatal error has occurred. Check the logfile above for details
 I've checked all my parameters and they are the same between my zipped and non-zipped file geodatabase.
Any idea why?
Thanks
