I am looking to insert a new feature into the output geodatabase here. The translations uses a feature reader to read a source geodatabase based on a user defined parameter which defines which feature classes the user wants to bring over. However I also need to add second feature class but instead of reading from a source I need to add a new record which i intialize from the creator. In this case though because the output writer uses a dynamic schema, I don't know how to insert this new feature or to indicate which feature class it should be written to. Any ideas?
Create new features
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
