Create a published parameter with date
geo-x
Dear FME community.
I've to use the dynamoDB connector with a partition key like a specific date (for example : today - 5 days).
For that I only can using a published parameter :
But in this case I don't have access to the date function :
Do you know how can I do that ?
For information, I've FME Server.
Thank you for your help.
Best answer by david_r
If you need today's date minus 5 days, you can use a private scripted Python parameter:
import datetime
today = datetime.datetime.now()
five_days_ago = today - datetime.timedelta(days=5)
return five_days_ago.strftime('%Y-%m-%dT%H:%M:%S%Ez')
To avoid considering the time of day, replace the last line with:
return five_days_ago.strftime('%Y-%m-%dT00:00:00+00')
You can then reference $(FIVE_DAYS_AGO) in the FeatureReader / reader.
  • July 23, 2020
import datetime
geo-x
  • July 24, 2020
import datetime
It's perfect !
Thanks @david_r !
