Create 3d surface from geotiffs
  • Feb 19, 2019 2:51 PM UTC
  • 354 views
Hi there!
I'm new to FME, so I apologize if I ask for a commonplace. My task is to create a 3D PDF, which will be a sequence of geological layers. Each layer is described by two files in the geotiff format - one corresponds to the top of the geological layer, the second to the sole.
I converted them to TIN-surfaces, afer which I tried to convert them to mesh, but the Mesh-builder transformer rejects them. I also tried to go the way of creating 3D polygons as in this example, but, again, I could not convert polygons to mesh.
Output example and 2 layers are attached.
Thanks!
whkarto
Forum|alt.badge.img+14
  • Feb 19, 2019 3:56 PM UTC
Use the SurfaceModeller Transformer and have a look at the TINSurface Output Port. There you'll find your Mesh. FME doesn't distinguish between Mesh and TIN, each TIN is of the geometry type Mesh.
