Count elements in json array
  • Apr 11, 2019 7:27 PM UTC
  • 6 replies
  • 857 views
jdh
Forum|alt.badge.img+41
I have a complicated json object that I would like to count the number of elements in one of it's child objects. Given the size and complexity of the original json, I would like to avoid flattening it and using the listElementCounter.
  • Apr 12, 2019 2:27 AM UTC
Try using the XMLXQueryExtracter with the JSONiq extension. This may be a kind of hack, but works.
Example:
A Complex JSON Text (value of a feature attribute called "_json")
    "a" : 100,
    "b" : {
        "c" : [
            {"x" : 1},
            {"x" : 2},
            {"x" : 3}
        "d" : 200
XQuery expression that returns the number of elements in the array "c".
jn:size(fme:get-json-attribute("_json")("b")("c"))
XMLXQueryExtractor Parameters
thijsknapen
Forum|alt.badge.img+12
  • Dec 22, 2020 12:23 PM UTC
Great, tnx for the info @Takashi Iijima​; Was looking for the same thing today 😃
peter_s
  • Mar 2, 2021 7:47 AM UTC
Yes, thanks @takashi - this saved my day!
salvaleonrp
Forum|alt.badge.img+23
  • Apr 1, 2021 9:02 PM UTC
What if the element attribute "x" has duplicated values and I want to count unique Xs only?
  • Apr 5, 2021 3:49 PM UTC
Hi @Renato Salvaleon​ , if I understand your requirement correctly, this expression returns your desired result.
count(
    distinct-values(
        for $e in jn:members(fme:get-json-attribute("_json")("b")("c"))
        return $e("x")
salvaleonrp
  • Apr 6, 2021 3:55 PM UTC
count(
    distinct-values(
        return $e("x")
Thanks @Takashi Iijima​ that got me the values I was looking for. It also saved me a good bit of process time by taking away four transformers and exposing my list attributes and exploding the features.
