Corrupt image file when reading and downloading from ArcGIS Portal
  • Apr 4, 2022 12:25 PM UTC
  • 135 views
jlw_tyrens
Hi all!
I have a workflow when I read and download image attachments from ArcGIS Online. I have used the AttributeFileWriter to download the image to a unique filename and it has always worked smoothley.
Now I am trying to do the same with image attachments from our ArcGISPortal and it works fine to read and download the files, but when I try to open the files it says that “It looks like we don’t support this file format.”
If I go to ArcGISPortal and manually downloads the image file, it works fine.
Does anyone recognize this phenomenon?
Best regards
Johan
jkr_wrk
Forum|alt.badge.img+37
  • Apr 4, 2022 12:37 PM UTC
Could it be that the file downloaded is (.png) for example and you write the file to disk with (.jpg).
Or other file format combination?
Opening a .jpeg with text editor shows me JFIF within the first 10 characters. Opening a .png shows png within the first 5 characters. I think .tif starts with II*
birgit
Forum|alt.badge.img+25
  • Apr 4, 2022 1:01 PM UTC
Another option is that the portal is still busy fetching the image while you are already downloading it though this might not be applicable for attachments. I have had something like this with exporting FGDBs from an ArcGIS Portal. I downloaded the FGDB while the portal was still busy exporting my service data to the FGDB, the result was corrupted FGDB files on my pc.
jlw_tyrens
  • Apr 4, 2022 1:20 PM UTC
Thanks for your reply! There is only jpg files in the feature service. That would have been a smooth solution on my problem..
jlw_tyrens
  • Apr 4, 2022 1:21 PM UTC
Thank for your reply! I will check into this.
