Converting GEOJSON to File Geodatabase
I am fairly new to FME and I need to convert a GEOJSON data link to a file geodatabase. I have not be able to find any help online for where to start.
Data link is here: https://data.menlopark.org/resource/vdp2-yzq3.geojson
Any help would be appreciated.
Thanks!!
danilo_fme
Forum|alt.badge.img+51
  • April 30, 2018
Hi @wjloy
You can start your Workspace with the option Generate Workspace:
File -> Generate Workspace
Please, set the configuration your Reader and Writer:
After this action, please confirm in OK button and the FME will create for you a Workspace Reader to Writer. Note that the transformer GeometryFilter will be in between the objects Reader and Writer.
Now, in the Writer - please - rename the attribute with strange character:
_@computed_region_bge3_x4j9 to for example computed
Attached the Workspace - workspacec-geojson-to-geodb.fmw
Thanks,
Danilo
  • April 30, 2018
danilo_fme wrote:
Hi @wjloy
Thanks,
Danilo
Hi Danilo-
Thanks for the reply, this is exactly where I got hung-up and I was using the wrong writer.
I will keep you posted on my progress.
Thanks,
Whit
danilo_fme
  • May 1, 2018
wjloy wrote:
Hi Danilo-
Thanks,
Whit
Excellent Whit. I am happy to help you
  • May 1, 2018
danilo_fme wrote:
Hi @wjloy
Thanks,
Danilo
Is there a way to change the name of the output feature types from vdp2_yzq3....?
danilo_fme
  • May 1, 2018
Yes. You can click on icon engine in the feature type and a window will open and you rename.
  • May 1, 2018
Thanks, I was getting an error yesterday when I tried this same approach. I guess I was over thinking it and attribute it to user error :-/.
danilo_fme
  • May 1, 2018
But, its works now?
