Converting Autocad Surface to a surface?
Folks I have an An autocad_surface that is listed as a fme_aggregate. Want to convert it to a surface via something like numericrasterizer. However its only doing the line edges of the triangles - and not the flat surfaces. Any thoughts? Should i run through deaggregator first ?
  • November 28, 2016
@pilgrimjake. Hi, have u solved yr issue? bumped into the same trouble, so would appreciate your help... Cheers!
mark2atsafe
Forum|alt.badge.img+44
  • November 28, 2016
As mentioned above, I would try a Deaggregator first. At the very least deaggregate the data and see what comes out using the FME Data Inspector. I believe an autocad_surface can contain not just surface features but meshes, faces, etc - and I doubt they would work as well in a rasterizer.
gio
Forum|alt.badge.img+15
  • November 29, 2016
Apart from deaggregating, try surfacefootprintreplacer. (works without aggregating too)
Though in case of donuts you should deaggregate, surfacefootprint replace and then clip to retain the hole(s).
