Convert multi-part polygon to single-part to load in PostGIS
  • Mar 15, 2018 1:04 PM UTC
  • 1217 views
Dear All,
I have an issue while using Dissolver and Aggregator I get multiarea of 5 polygons, which look merged in the Inspector. But when writing to PostGIS, aggregated geometry is split again into separate polygons. PostGIS is accepting only polygons as geometry. I know that if the PostGIS accepts only single polygon, but writer attempts to load a collection, then a collection will be split. The question is if there's a way to aggregate multiple polygons into one without collection. Single polygon needed only to set the extent of the layer, so envelope like feature will do as well.
Thanks a lot for your answer.
Forum|alt.badge.img+63
You can use the Deaggregator to split aggregate polygons. However, according to the docs PostGIS should support aggregates so I'm really curious about those polygons. Any chance you can post a sample here?
lars_de_vries
Forum|alt.badge.img+10
It might has to do with the geometry settings in PostGIS. There is a seperate geometry type for multipolygon. Maybe the issue lies in there.
