Convert JP2 to ECW and create TAB file as well.
  • February 20, 2022
  • 97 views
I use to run the conversion process of GeoTiff to ECW with compression of 90 and generate TAB file using FME2020, i never experienced any issue.
I recently upgraded FME to 2021.2, I have to convert JP2 to ECW with compression of 90 and want TAB file as well.
I ran the process multiple time, but I don't get TAB file generated in output folder.
Even I found new attribute in this FME version, where it asks to select ECW Format version (2 or 3), which one to select..?
Best answer by rapidmapper
rapidmapper wrote:
Hello, Thank you for your response. I have writer settings pretty much same as in your screenshot..
ECW-writer-settingsecw-writer-settings2
I got it what was the issue, I was using Trial version which has a limitation to transform ECW and generate TAB file.
Once I tried same process on my licensed FME machine,it works..
Not documented anywhere, lesson learnt hard way.
Forum|alt.badge.img+49
Do you have the paramter "Tab File Generation" set on the ECW writer feature type?
Screenshot 2022-02-21 at 09.58.19As for the version, generally speaking it would be best to pick the latest version unless you have a very good reason not to do so (such as the application you want to use the ECW in not supporting that new version). So it's really up to you.
  • February 21, 2022
Does the JP2 file that you're reading have a coordinate system set?
  • February 23, 2022
