Convert demensions from CAD to GDB
  • Jul 26, 2013 9:11 AM UTC
  • 57 views
I don't kown how to convert the dimension geometry entity,and I need a model of FME to solve the problem.
Another, I also need convert the GDB feature like dimensions to CAD formate.
thank you.
Best answer by conterrastefan
Hi Sophie,
it is possible to translate dimensions from CAD to GDB. In generall you need to copy the CAD dimension attributes into the corresponding geodb_dimension attributes. In he readers and writers help you can find these:
FME Readers and Writers (formats supported by FME 2013 SP2) > Esri Geodatabase Reader/Writer > Feature Representation >Dimensions
Moreover here is a FMEPedia article that deals with the topic, too.
http://fmepedia.safe.com/articles/Samples_and_Demos/Creating-AutoCAD-Dimensions
 Best regards,
Stefan
Hi Sophie,
 Best regards,
Stefan
