Compare and update Json into DB
  • Jul 20, 2020 8:52 AM UTC
  • 5 replies
  • 123 views
geo-x
Dear FME community.
I would like to compare to database who contains json (with subobjects).
The aim is to UPDATE, DELETE or INSERT json into the target DB
Inforamtion : the base 2 may be to json format or "classical" attributes format.
What is the better way to do this ?
Thanks.
  • Jul 20, 2020 12:11 PM UTC
Hi @lalandexavier, a possible way I can think of is, use the JSONExtractor to extract ID and other attributes which you need to compare and then use the ChangeDetector to compare the objects.
geo-x
  • Jul 20, 2020 2:13 PM UTC
Hi @takashi it's a pleasure to read you.
In this case I'm reading data from AWS DynamoDB, it's NoSQL DB.
I checked the field dynamodb_Json in String type :
In the transformer JSONExtractor I can do the extract like that :
And that's ok !
Now I've a problem with the ChangeDetecor because I've ID to join and I can't do that with this and I've a problem with the date.
I've the same values but the ChangeDetector give me Added and Deleted :
Do you understand how can I do ?
geo-x
  • Jul 20, 2020 3:11 PM UTC
Sorry it's ok I had problem with the Parse of my date. But How can I do a join on ID with the ChangeDetector ?
  • Jul 20, 2020 3:27 PM UTC
Try setting the ID attribute to the Update Detection Key Attribute parameter.
geo-x
  • Jul 22, 2020 12:23 PM UTC
I think you're a most modern version version of FME than me :-)
