Combine multiple KML files into one
Hello - in FME Workbench 2018.1 I am adding 2 KML Readers (a point file and a polygon file) to a workspace, and just want to combine them into one KML Writer containing the points, polygons and user attributes. When I inspect the reader I can see the attribute table with all the user attributes, but when I inspect the writer there is no attribute table. The only transformer I have is KMLPropertySetter, and Include Attribute Table has "Yes" selected. What do I need to do to include the user attribute table in my resulting KML file?
Thank you
Forum|alt.badge.img+38
  • July 25, 2019
Do you have the attributes set on the writer?
  • July 26, 2019
Thank you for your reply. I do - they are set to Automatic and I can see them in the drop-down below the Writer.
