Collapse (text) records where contiguous
  • Feb 27, 2014 10:39 AM UTC
  • 15 replies
  • 96 views
Can anyone help me devise a method using FME to collapse a series of text records with no associate geometry, assuming that 2 values are equal and 2 values are contiguous. I have included some example data below, data is arrange such that the Animal and Colour values must match the preceding row and the preceding End value must match the Start value.
I have a very nasty script for excel which may be possibly be adapted, but I would really like to do this with FME.
I have tried to do some of this within a loop but got a bit lost. Could it be down using transformers or a Python script which can be included in a bench? Ideally any method needs to be adaptable as I would like to use it for other data sets with differing field names and more or less matches required.
Animal, Text
Colour, Text
Start, Int
End, Int
Input Data Format
Animal,Colour,Start,End
Dog,Blue,0,1
Dog,Blue,1,5
Dog,Blue,5,10
Dog,Red,31,35
Dog,Red,35,56
Cat,Purple,101,102
Cat,Purple,103,106
Cat,Purple,106,111
Required Output Data Format
Dog,Blue,0,10
Dog,Red,31,56
Cat,Purple,101,102
Cat,Purple,103,111
Thanks in Advance,
Rob
  • Feb 27, 2014 11:15 AM UTC
Hi Rob,
There are several ways. One is:
1) Aggregator
Group By: Animal, Colour
Keep Input Attributes: No
List Name: _list
2) ListIndexer
List Attribute: _list{}
List Index: 0
Demoted Attribute Prefix: first_
3) ListIndexer_2
List Index: -1    (-1 indicates the last element in the list)
Demoted Attribute Prefix: last_
4) AttributeRenamer
Old Attribute  |  New Attribute
first_Start  |  Start
last_End  |  End
Takashi
  • Feb 27, 2014 11:39 AM UTC
# re-post. correction for typos...
Another approach. Maybe this is simpler and more general.
1) StatisticsCalculator (Summary)
Attributes to Analyze: Start, End
2) AttributeRenamer
Start._min  |  Start
End._max  |  End
  • Feb 27, 2014 12:07 PM UTC
Hi Takashi,
As always thanks for the help. I have implemented the first solution using the Aggregator and the List Indexers and it has nearly worked. However, in the example above some successive records may match in terms of Cat and Purple, but there may be gaps in terms of successive  End and Start values (which I want to retain). When I used the min and max (0 and -1) indexes the gap is effectively closed or ignored. Do you think there is a way to account for this?
Cat,Purple,101,102 (gap for next start)
Cat,Purple,103,111
Regards,
Rob
  • Feb 27, 2014 1:11 PM UTC
Ah, I missed that condition.
How about creating a group ID by comparing Start of current row to End of previous row?
1) AttributeCreator
Attribute Name: GroupID
Value: <any>
Just create the attribute name. It can be replaced with the AttributeExposer.
2) AttributeCreator_2
Check Multiple Feature Attribute Support option.
Number of Prior Features: 1
If Attribute is Missing, Null or Empty: Use Other Value
Attribute Replacement Value: 0
Value: 2 Possible Values (Conditional Value setting)
If @Value(Start) = @Value(feature[-1].End) Then feature[-1].GroupID
Else @Evaluate(@Value(feature[-1].GroupID) + 1)
3) StatisticsCalculator (Summary)
Group By: Animal, Colour, GroupID
4) AttributeRenamer
Start._min  |  Start
End._max  |  End
  • Feb 27, 2014 2:44 PM UTC
Hi Takashi,
Thanks for the revised settings, I managed to complete step 1 and then got stuck.
For info I am using FME2013.
I started on step 2 but could not find the check Multiple Feature Att support and the other settings i.e/ # prior features. (is this avaiable in 2013 or am is it user error (most likely!).
Also I tried to enter the conditional value setting but did not manage to enter teh setting in correctly.
Sorry for being a pain but could you  include a screen shot/s of this bit. when i have done it once I will be ok.
Regards,
Rob
  • Feb 27, 2014 3:41 PM UTC
Multiple Feature Attribute Support was added in FME 2013 SP2 (or SP1?).
Well, replace two AttributeCreators with a PythonCaller.
Attributes to Expose: GroupID
import fmeobjects
class GroupIdSetter(object):
    def __init__(self):
        self.groupId = 0
        self.prevEnd = 0
    def input(self, feature):
        start = int(feature.getAttribute('Start'))
        if start != self.prevEnd:
            self.groupId += 1
        feature.setAttribute('GroupID', self.groupId)
        self.prevEnd = int(feature.getAttribute('End'))
        self.pyoutput(feature)
    def close(self):
        pass
gio
Forum|alt.badge.img+15
  • Feb 27, 2014 4:08 PM UTC
I made a little workspace doing this.
Il put it on chatter
gio
  • Feb 27, 2014 4:15 PM UTC
Uploaded on chatter,
its a tiny piece of tcl, and mostly transformers, in fme 2013.
gio
  • Feb 27, 2014 4:36 PM UTC
..ok what it does.
listbuilder on col0 an dcol1 (Animal and Color)
2 listconcatenators. 1 on col2 and 1 on col3 (start, end).
Then i use a little tcl to remove the intersection:
In tcl caller
Tcl Expression: listcompare @Value(Start) @Value(End)
Source Code:
proc listcompare {a b} {
  set a [split $a ","]
  set b [split $b ","]
  set a_no_intersect {}
  set b_no_intersect {}
  foreach i $a {
    if {[lsearch -exact $b $i]==-1} {
      lappend a_no_intersect $i}
    foreach i $b {
    if {[lsearch -exact $a $i]==-1} {
      lappend b_no_intersect  $i}
  FME_SetAttribute Start_ $a_no_intersect
  FME_SetAttribute End_ $b_no_intersect
Attributesto expose: .Start_ End_
then 2 attributesplitters on Start_  and End_,
listelementcounter on Start_ (or End_),
attributecreator: index 0
custom transformer to read out the 2 attributes:
  •   2 listindexers on Start_ and End_ with Listindex : Index
  • test on index.
  • Tester:
    the trick here is to attach the passed and failed from the tester to output.
    failed and raising index you must attach to loop to input.
  • so the tester fail ports gopes to output and loop to input. If u dont it will only output the last element in the list.
matcher : on col0 trough 3. (because the loop proces dups)
i put it on chatter anyways..
haves funs!
Gio
  • Feb 28, 2014 4:04 AM UTC
I also created a workspace example with FME 2012 SP4.
https://safecommunity.force.com/068a000000456Dq
  • Feb 28, 2014 8:29 AM UTC
Hi Takashi,
Thanks very much for the worked examples I will look at these over the weekend.
I checked and I do have 2013 SP1.
Also i tried to set up the pythoncaller with teh script last night and kept getting an error SYMBOL_NAME requires arguement; there was clearly something that I had missed. However the worked exmaple you have sent will be great to work through and i am sure that i will be able to follow the steps.
Thanks again for taking the time to construct this for me.
On a related note I reworked a workbench a few weeks ago and used SQL to preform a join between query which you helped with, this had previously been based on feature merge and then tests. i implemented the SQL version it took 6 minutes instead of the FM version whcih took 2Hrs and 5mins. A significant improvement.
Best wishes,
Rob
  • Feb 28, 2014 8:32 AM UTC
Hi Gio,
Thanks very much for sending the TCL and list concat solution via chatter, I will look at this over the weekend.
I love that fact that you can obtain the same result within FME but use completely differing ways of implementing a solution.
Best wishes,
Rob
  • Feb 28, 2014 8:55 AM UTC
Hi Rob,
I updated the example, added full Python edition. You can download ver.2 from the same URL.
I expected that the SQL would be faster, but couldn't imagine such a significant improvement. The information will be very helpful for me.
Thank you for the notification.
Have a nice weekend.
Takashi
  • Mar 3, 2014 2:58 PM UTC
Hi Takashi,
Many thanks for sending through v7 with all the additional methods for resolving this issue I will send some further reviewing the alternate methods, and select the most appropriate based on my service pack type.
I spent some time working through the 2 methods that you sent on Friday; due to my SP issues I implemented the variable based version, it worked a treat. Once I understood the process flow, I tested if I could add in another variable/condition which much be met.
(See below) I Included an extra variable (vPrevHat) and test condition (vPrevEnd = Start  AND vPrevHat = Hat) which much be met in order to collapse the record, it worked well.
Input Data Format
Animal,Colour,Start,End,Hat
Dog,Blue,0,1,Tophat
Dog,Blue,1,5,Tophat
Dog,Blue,5,10,Fedora
Dog,Red,31,35,Baseball Cap
Dog,Red,35,56,Baseball Cap
Cat,Purple,101,102,Fez
Cat,Purple,103,106,Fez
Cat,Purple,106,111,Fez
Output Data Format
Dog,Blue,0,5,Tophat
Dog,Red,31,56,Baseball Cap
Cat,Purple,103,111,Fez
Depending on the compatibility of the new methods with my SP I may change, it is good to see the number of approaches which can be taken to solve a problem.
As always thanks again.
Best wishes
Rob
  • Mar 3, 2014 3:13 PM UTC
Good to hear you got your own solution.
This is an interesting subject, was also a good material for my own self training. To Think of multiple approaches for the same goal is always a good training.
Cheers!
