Clean line breaks from Excel file? (Reader)
  • Dec 18, 2018 1:36 PM UTC
  • 199 views
Hi all,
After some investigation I found out my Excel reader file contains "line breaks" causing FME to write the content of a single Excel cell to multiple lines.
Is there a way in FME to clean line breaks?
Thanks,
Ed
Best answer by david_r
You can use a StringReplacer:
Text to replace:
\n
For replacement text you can either leave it blank or use a space, depending on what you need.
  • Dec 18, 2018 1:50 PM UTC
Text to replace:
\n
  • Dec 18, 2018 2:11 PM UTC
Text to replace:
\n
@david_r
Thanks David, that did the trick!
These "invisible" characters kill me every time.
Cheers,
Ed
  • Dec 18, 2018 2:12 PM UTC
@david_r
Cheers,
Ed
You're not the only one struggling with those...! Glad to hear it worked out.
