Cannot import CSV to SQL Server Geodatabase
  • Mar 21, 2019 3:19 PM UTC
  • 48 views
I am trying to import a csv file to a SQL Server geodatabase - 10.6.1. There are only 2 fields and 66 records. I am getting the following error: Destination Feature Type Routing Correlator(RoutingFactory): COM.safe.fmeobjects.FMEException: Feature attribute not found or could not be represented as UTF-8 String: fme_template_feature_type
andreaatsafe
Forum|alt.badge.img+17
This issue was resolved by using the Esri Geodatabase (ArcSDE Geodb) (shortname: GEODATABASE_SDE) writer instead of the SQL Server Non-Spatial writer.
