Cannot get cesium 3d tiles to display
  • May 20, 2020 10:44 PM UTC
  • 5 replies
  • 256 views
Hello all,
I have been trying to convert a topjson/geojson file to a cesium 3d tileset. I have been able run the conversion but i cannot get it to display in cesium. I feel that this may be caused by the coordinates not being converted correctly. I cannot figure out how to fix it. I tried using no coordinate system selected and LL-WGS84, but neither worked. I did notice the area cesium zoomed to changed but i could still not see the shapes. Any help would be greatly appreciated. Below is a link to the geo and topo json files i tried.
https://le-temp-public.s3.amazonaws.com/counties-us.topo.json
https://le-temp-public.s3.amazonaws.com/counties-us.geo.json
Again thanks
itsmatt
Forum|alt.badge.img+48
  • May 21, 2020 5:41 AM UTC
Does your Cesium map have a terrain? Could the data be under the terrain at 0 elevation? Have you checked the network section developer mode in your browser (F12) to see if .b3dm files are getting downloaded? I have found that converting to WGS84 gives best results in our maps, however, this could be due to configuration.
itsmatt
  • May 21, 2020 5:44 AM UTC
Also, if you add a background map to the data inspector and set the coordinate system of your data to LL84/WGS84 you should see your data in the right place in the 2D view (it will look really weird in 3D view but that's normal when in LL84).
If the coordinate system is showing 'Unknown' then the data are likely to be placed incorrectly. If they are 'Unknown' you need to set the coordinate system of your input geojson file
  • May 21, 2020 2:54 PM UTC
So i added a map box background and i now see the problem. The shapes are tiny and not visible when i am not zoom very far in. I tried changing the coordinate system but tat had no effect. Do i need to scale? or transform the lat/long?
  • May 21, 2020 2:56 PM UTC
Scratch that last comment i had to reload the view. So i now see the shaped on the map correctly, but i still can see them on cesium. I am going to try and play with the elevation. as Suggested abbove
  • May 21, 2020 6:35 PM UTC
I found the problem. When i tried the tileset in cesium sandcastle it worked. It has something to do with the cesium configuration in my app.
