Can the Generic writer write a PRJ file when writing ACAD?
  • Jun 1, 2023 5:25 PM UTC
  • 88 views
bruceharold
Forum|alt.badge.img+20
I would like a PRJ file written alongside the DWG when using a dynamic format workflow. The bespoke AutoCAD writer has a setting, just looking for how to do with with a dynamic workflow.
Best answer by daveatsafe
Hi @bruceharold​,
If you add an AutoCAD writer in addition to the Generic writer, but don't create any output feature types for it, the settings for that writer will be used whenever the Generic writer writes to that format. This is the usual method we recommend for fine control of the Generic writer output.
daveatsafe
Forum|alt.badge.img+24
  • Jun 1, 2023 10:59 PM UTC
Hi @bruceharold​,
bruceharold
  • Jun 2, 2023 1:05 PM UTC
Works perfectly thanks Dave!
