Can't read events from Azure EventHubs using AzureEventHubsConnector
  • June 23, 2022
  • 64 views
siriosus
Forum|alt.badge.img+4
Hello FME Community
I'm getting following error when trying to read events from Azure EventHubs using AzureEventHubsConnector:
Python Exception <TypeError>: Message data is not compatible with string type: 'generator' object has no attribute 'decode'
All parameters were set correctly and events are actually passing through other clients.
Thank you in advance!
JennaKAtSafe
Forum|alt.badge.img+8
Hi @siriosus​, hard to tell what the feature/attribute generator and decode means without an example of your workspace. Could you provide some more context on this?
