Can't login to PostgreSQL with password containing '#' to user created with FME SQLExecutor
  • Sep 6, 2019 8:55 AM UTC
  • 138 views
My FME workspace runs a SQLExecutor which creates an user with provided username and password as attribute:
CREATE USER "@Value(username)" WITH PASSWORD '@Value(password)';
GRANT @Value(roles) to "@Value(username)";
On containing a '#' in the password value, I'm not able to connect to a database through that created user in QGIS. Unfortunately I can't expose the password handed over in pgAdmin to check the password set by FME. After changing the password in pgAdmin to another password containing the '#' as well, the connection works. Therefore I suppose the error to be within the SQL Executor. Does FME encode that character in some way, so that the '#' is stored as other character(s)?
  • Sep 6, 2019 9:17 AM UTC
First of all, don't use double quotes around the strings, only use single quotes. In SQL, double quotes are for object names, single quotes are for strings.
Also, you need to add an FME_SQL_DELIMITER definition since there are two separate statements that need to be executed separately.
Which gives us:
FME_SQL_DELIMITER ;
CREATE USER '@Value(username)' WITH PASSWORD '@Value(password)';
GRANT @Value(roles) to '@Value(username)';
Notice that there is a space between FME_SQL_DELIMITER and the semi-colon.
  • Sep 6, 2019 9:30 AM UTC
Which gives us:
FME_SQL_DELIMITER ;
The username has to be in double quotes, because we have a '-' in every username value. With single quotes it throws a syntax error. I don't think that's the problem, until now it worked without problems. Just with a '#' in the password.
I've already using the FME_SQL_DELIMETER statement, I just didn't post it in my code example.
  • Sep 6, 2019 10:54 AM UTC
You are indeed right about the double quotes in this instance! I didn't know about this "non-standard" behavior in Postgresql, very interesting.
  • Sep 6, 2019 10:57 AM UTC
It looks like PostgreSQL is trying to be intelligent about the password string, which may have weird side effects if e.g. the password starts with a # or contains any backslashes.
You can tell PostgreSQL to not parse the string contents by prefixing it with an E just before the single quotes.
This worked for me:
FME_SQL_DELIMITER ;
CREATE USER "@Value(username)" WITH PASSWORD E'@Value(password)';
Documentation: https://www.postgresql.org/docs/9.2/sql-syntax-lexical.html#SQL-SYNTAX-STRINGS-ESCAPE
