can not read oracle data - bad geometries
  • May 23, 2018 1:07 AM UTC
  • 66 views
I have a oracle spatial reader setup to read a number of tables. All the tables can read except one table and the reader stops automatically with a error message in the log - Error - Cannot have NULL value for 'x coordinate'. I tried to filter the bad geometries with a where clause like this - SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT( G3E_GEOMETRY, 0.005, 'TRUE') = 'TRUE' . That did not work either and the same error followed. Surprisingly when I used this sql statement at SQLDeveloper, it results in a set of valid records. I am not sure why FME is not able to read these valid records.
Appreciate if you could help me out with this.
  • May 23, 2018 7:15 AM UTC
You can try and debug the contents of the table in question using a SQLCreator (rather than the Reader) set to Oracle non-spatial and something like this:
SELECT MY_ID, SDO_UTIL.TO_WKTGEOMETRY(GEOM) AS WKT_GEOM FROM MY_TABLE;
You can then use the GeometryReplacer on WKT_GEOM (set to OGC Well-Known Text) and inspect whatever comes out the Rejected-port.
