Can I copy the schema of an existing feature class
  • Oct 15, 2013 12:45 PM UTC
  • 164 views
I'm migrating data into a file geodatabase in which I currently have one feature class that is in my standard format. I want the data im mnigrating to this geodatabase to be stored in a number of feature classes with identical schema. Is there a way to either copy the feature class and change its name and contants each time, or copy its schema?
Thanks,
Chris
Best answer by david_r
you can either import a feature type using the menu Writers / Import feature types or copy/paste an existing feature type inside the workspace and then rename it manually.
Another option is to export the XML schema using ArcCatalog, then using it as a template in FME. There is a screencast here that shows how.
David
  • Oct 15, 2013 12:57 PM UTC
David
