Can FME write to an Excel table?
michielschram
I have got some beautiful Excel templates containing tables (not normal ranges). It's quite easy to write to a named range within Excel but I haven't figured out how to write to a Table. Does anyone know how to do so?
Best answer by fmelizard
Hi @michielschram, depending on the complexity and number of tables you have, this can be done in FME. I have only tested with one table in my sheet, but FME is able to append additional records. I've used the "Import from Dataset" option when adding my Writer to import the data model from the sheet.
If you have a sample of the tables you're working with, I'd be more than happy to investigate further for you. I imagine your tables will be more complex than my test.
fmelizard
Forum|alt.badge.img+19
  • July 28, 2017
craigvernon
Participant
  • Participant
  • July 28, 2017
FYI, we hosted a webinar this week " Tips for Automating Excel Data Processing Tasks with FME ". It doesn't answer your question specifically but there are some great nuggets of information and you can download the workspaces used in the demo.
michielschram
  • July 28, 2017
Yes, did watch the webinar and looking forward to the advanced Excel webinar... ;-)
gis_midwest
Forum|alt.badge.img+4
  • August 27, 2024
Is there any more detail on how writing to an excel table can be accomplished?
I’ve been attempting to do so but it seems that FME creates a range in place of the table object and writes to it, not the table itself.  It also seems to cause the file to become corrupted when doing so.  Hope someone else can shed some light on this.
Thx.
ekkischeffler
Hi ​@fmelizard, I’m aware that this is a really old post. Would you still be able to provide some details on this? I’m having the same issue as ​@gis_midwest. My sheets get corrupted when I try writing into an existing table. I have tried the “Import from Dataset” method as well as using a template with a table set up in it. I’d appreciate your help!
