I’m fairly new to FME. I’m using FME Workbench 2023.1. I am trying to recreate an excel output similar to the below image, but I’m not sure FME is capable since there isn’t much information out there on using FME to write an excel output like what I have a need for… All I see is more simple outputs. I need to be able tie the output values of a lot of those cells to data created in other transformers, but since the layout is not your typical excel sheet layout, I can’t seem to find any info if you can use a template and then tie the output from another transformer to the particular cell it goes with in the excel template. If anyone knows where I can find more information on this, I would greatly appreciate the help!
