Can FME call and read from an Oracle pipelined function?
  • Mar 13, 2017 6:18 PM UTC
  • 57 views
Is there a way to call a pipelined function with parameters and then read the results as a table in FME desktop? I am only interested in non-spatial attributes being used.
Thanks in advance...
Best answer by erik_jan
I think the SQLCreator should be able to do that.
This transformer acts as a reader, based on a SQL statement.
The statement will be passed to the database and the result will be read into FME.
Hope this helps.
erik_jan
Forum|alt.badge.img+26
  • Mar 13, 2017 6:35 PM UTC
Hope this helps.
  • Mar 13, 2017 8:16 PM UTC
Thanks Erik, that works great. Make sure to specify Automatic or Manaul for user attributes for anything consuming the data however, since FME does not pre-parse the return types for Dynamic with this type of call.
