Can FME be launched from PowerShell?
  • Jul 25, 2017 3:40 PM UTC
  • 15 replies
  • 431 views
tim_wood
Forum|alt.badge.img+8
I've been trying to run an FME Workspace using PowerShell but I'm getting errors. At the moment, it's just a test Workspace with a Creator and an Emailer.
When the FMW is on a different server in a different domain, I get an error saying the FMW file could not be opened. I am mapping a drive to the other server in the PowerShell console before I try to run the Workspace.
When the FMW is on the same server as the EXE and PowerShell window, I get "A fatal error has occurred. Check the logfile..." although the Workspace did seem to have completed.
I've tried the same things in a Command Prompt window with no errors so I'm going to use a Batch File for now.
  • Jul 25, 2017 3:43 PM UTC
Can you be a bit more specific?
trentatsafe
Forum|alt.badge.img+7
Hello @tim_wood,
As @david_r suggested, are you able to be more specific/provide more details? Using a simple workspace(creator and logger) I was able to successfully run an FME workspace using Windows PowerShell. I also tried running a workspace that was hosted on a network drive and it was successful as well.
tim_wood
  • Jul 26, 2017 8:34 AM UTC
Hello @tim_wood,
Thanks both.
I'm running it on Windows Server 2008 and have found differences between PowerShell there and code samples from the internet which I think are for later versions of Server/PowerShell.
I'm trying to use PowerShell or a batch file to script the running of FME because I want to run the Workspace as a Scheduled Task. Our server team believes authentication issues a preventing this from working directly i.e. specifying fme.exe and the FMW in the task, and have suggested calling a script which will map a network drive and run the Workspace.
Now I know it's possible with PowerShell I'll continue working on it.
lars_de_vries
Forum|alt.badge.img+10
Hi @tim_wood,
It is also very easy to create a batch file from a Workspace. You'll just have to copy the first blue rules from the log file and save them as a batch file. Using Task Manager you can schedule the batch file to run.
The first line describes which model to run using which FME instance. The following lines describe the parameter settings.
  • Jul 26, 2017 9:14 AM UTC
I suspect your issue may be more related to the task scheduler than FME, there are some known gotcha's when running powershell and/or batch scripts.
Have a look at e.g. this article for more info on how to run a powershell script from the task scheduler: https://blogs.technet.microsoft.com/heyscriptingguy/2012/08/11/weekend-scripter-use-the-windows-task-scheduler-to-run-a-windows-powershell-script/
tim_wood
  • Jul 26, 2017 9:23 AM UTC
Hi @tim_wood,
Thanks. Normally, I don't even need to use a batch file/PS script, I just call FME and the Workspace direct from Task Scheduler. However in this case I'm trying to conquer this pesky cross domain issue.
tim_wood
  • Jul 26, 2017 9:25 AM UTC
Thanks. I think I've been on that page already when trying to find out how to run an EXE from PowerShell - sometimes Google search results don't have the answer! ;-). I haven't got to the point of putting it into task Scheduler yet. I want to get the PowerShell script working before I set it up as a task.
p-chessel-vdg
Forum|alt.badge.img+4
I want also to user Powershell instead of .cmd or bat files to run FME scripts embedded in some other powershell functionnality.
I have been able to run fme.ex with parameters using below powershell scripting:
$FME_CMD = $FME_EXE + " " + $FME_SCRIPT + " " + $FME_OPTIONS
$processFme = cmd.exe /c $FME_CMD 2> $null
It works, but I still get an error (not problematic) about the output of the "Translation was SUCCESSFUL" string at the end of the process.
Is there a way to handle properly this "Translation was SUCCESSFUL" string ?
Reading...
Emptying factory pipeline...
C:\\apps\\FME2020\\fme.exe : Translation was SUCCESSFUL
At D:\\fme_scripts\\adp\\foodtrucks\\food_trucks_update.ps1:5 char:1
+ C:\\apps\\FME2020\\fme.exe D:\\fme_scripts\\adp\\foodtrucks\\food_trucks_upd ...
   + CategoryInfo         : NotSpecified: (Translation was SUCCESSFUL:String) [], RemoteException
   + FullyQualifiedErrorId : NativeCommandError
jovitaatsafe
Forum|alt.badge.img+11
Reading...
Hi @p-chessel-vdg​,
It looks like this thread was from a few years ago and you've got a good question. Would you be open to posting it as a new question in the Forums for better visibility?
p-chessel-vdg
hi,
I have solved the issue : using the cmd.exe / c command in powershell, i am able to launch fme.exe with parameters and catch the output
  $FME_CMD = $FME_EXE + " " + $FME_WORKSPACE + " " + $FME_OPTIONS
   echo $FME_CMD >> $LOG_FILE
   echo $processFme >> $LOG_FILE
  • Sep 29, 2020 7:21 AM UTC
hi,
Just be aware that you're launching the regular shell here (not Powershell) as a sub-process through cmd.exe and then letting it start FME for you.
Another option is to use the & call operator in Powershell:
& $FME_EXE  $FME_WORKSPACE  $FME_OPTIONS
This will execute FME directly under Powershell, avoiding one extra layer.
See also https://ss64.com/ps/call.html
https://docs.microsoft.com/en-us/powershell/module/microsoft.powershell.core/about/about_operators?view=powershell-7#call-operator-
p-chessel-vdg
With $FME_CMD = $FME_EXE + " " + $FME_WORKSPACE + " " + $FME_OPTIONS ,
using the native & FME_CMD syntax does not work:
I have following error wich lookes linked to passing fme workspace and options:
The term 'fme.exe D:\\fme_scripts\\***\\***\\******.fmw --DestDataset_FILEGDB \\\\***\\***\\***\\***.gdb --Connection_GEODATABASE_SDE D:\\fme_ressources\\sde\\******.sde' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
The same $FME_CMD string works fine with cmd.exe: $processFme = cmd.exe /c $FME_CMD 2> $null
  • Sep 29, 2020 8:44 AM UTC
The term 'fme.exe D:\fme_scripts\***\***\******.fmw --DestDataset_FILEGDB \\***\***\***\***.gdb --Connection_GEODATABASE_SDE D:\fme_ressources\sde\******.sde' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
Is it possible that you're doing this?
& $FME_CMD
That would not work and I would expect the error shown. The command will have to be exactly as I posted above:
 There's a small possibility that you'll have to also split up the different option key/pairs. So in the end it's a trade-off between beeing pragmatic and being efficient :-)
p-chessel-vdg
When I perform an & $FME_EXE + $FME_WORKSPACE + $FME_OPTIONS
I get an error related to wrong number of parameters (even) , this error does not appear with cmd.exe /c
fme.exe :
At D:\\fme_scripts\\***\\\\*****.ps1:32 char:5
+    & $FME_EXE + $FME_WORKSPACE + $FME_OPTIONS
   + CategoryInfo         : NotSpecified: (:String) [], RemoteException
Expected an even number of command line arguments, instead got 3 for command line: >> `D:\\fme_scripts\\***\\***.fmw' `+'
`--DestDataset_FILEGDB \\\\***\\***.gdb --Connection_GEODATABASE_SDE_ADP
D:\\fme_ressources\\sde\\***.sde' <<
Program Terminating
Translation FAILED.
p-chessel-vdg
& $FME_CMD
Yes,if i split the options it works.
So now i don't need to use the cmd.exe /c , native powershell & is fine.
Thanks
 & $FME_EXE $FME_WORKSPACE $FME_OPTION_1 $FME_OPTION_2 2> $null
