Building Spaces from walls
  • Feb 28, 2018 9:24 PM UTC
  • 33 views
Hi All,
I'm having trouble with developing room polygons from walls for a building from an autocad file. The difficult part is snapping lines together. I have a workflow, but it only completes about 50% and the rest will not budge. Attached is the workbench along with the CAD file.
Any suggestions would be appreciated!
David
building-spaces.fmw
lars_de_vries
Forum|alt.badge.img+10
Hi @david_prosack88,
good to see that you solved your own problem. Could you share your solution? This will help other users with similar problems.
