AWS Region Detection in S3Uploader
  • Jun 14, 2017 2:21 PM UTC
  • 88 views
Hi all,
We're attempting to use S3Uploader in FME 2015.1.1 and FME 2016.1 to upload data to a bucket in ap-southeast-2 (Sydney), but we're receiving an error from AWS that seems to indicate that FME is not uploading to ap-southeast-2.
“The bucket you are attempting to access must be addressed using the specified endpoint. Please send all future requests to this endpoint. (Service: Amazon S3; Status Code: 301; Error Code: PermanentRedirect;”
Googling this error results in many bug reports from other software using AWS where they have forgotten to specify an AWS region, and it's defaulted to a different region than where their bucket resides.
According to FME's documentation here, our AWS region should be automatically detected.
"As of build 2015.1.1, all AWS transformers support multiple regions. You don't have to do anything we automatically detect the region."
We've been unable to find any further information about how the automatic detection works, or how we're able to override it.
Is anyone aware of any workarounds for providing FME's AWS transformers with a hard-coded region?
Cheers,
Keith
scyphers
Participant
Forum|alt.badge.img+5
  • Participant
  • Jun 14, 2017 7:26 PM UTC
Hi Keith,
I do not have 2016.1 to properly test but i have been able to repeat the 301 status error if i specify a correct/valid bucket name but specify a wrong region in the S3Uploader.
The odd thing about S3 is that the DNS rules are 'different' in us-east-1 Virginia. I think even case sensitive bucket name spaces are honoured. Every other region came after and more stringent rules were applied from day 1.
So my hacky workaround given that all AWS buckets are globally unique, If you provide the transformer with the name your ap-southeast-2 Sydney "located" bucket <uswest1-bucket> and point FME at us-east-1 Region you should be able to let AWS resolve the DNS on the S3_PUT and your files will land in Sydney bucket.
The reason this works (for now) is that a bucket maybe does not support redirection thru REST API and under the hood the calls probably look something like putting something in Virginia us-east-1
http://
bucketname
.s3.amazonaws.com
And every other region  look something like.
 http://s3-
region
.s3.amazonaws.com/
bucketname
So please try to Lie to your S3Uploader and see if you can upload your files to Sydney Region by naming you correct/valid bucket name but then using the wrong generic Virginia <us-east-1> Region.
  • Jun 21, 2017 1:35 AM UTC
Ta for the tip, Steven!
Unless I'm missing something, I'm not sure that's going to work for us though - we have no control over the region in S3 Uploader in FME 2015/16. All we can set is the bucket name and FME.
Actually according to this blog post from Safe our FME 2015/16 should already be trying to use the us-east-1 'trick'?
Our other hacky workaround we may fallback to for now is to drop down to Python Shutdown Script and handle uploads via Boto.
  • Jun 24, 2022 6:14 AM UTC
