Avoid automatic date conversion
  • May 30, 2024 7:46 AM UTC
  • 135 views
david_
Forum|alt.badge.img+8
Is there any way to prevent FME Desktop from converting dates to its internal format?
For example, if you get '2024-05-30' I want it to remain '2024-05-30' and not '20240530'.
I understand that it can be useful in some cases but there are others that this automatic conversion becomes a headache.
Thank you!
Regards.
liamfez
Forum|alt.badge.img+44
  • May 30, 2024 2:08 PM UTC
The DateTimeConverter will allow you to convert between time formats.
If you were wanting FME to not treat the values as a date from the start, then you could change the format type for that attribute in the reader to string/text instead of date.
