Aviod geometrycollection in MS SQL?
  • Dec 5, 2017 3:16 PM UTC
  • 75 views
m_tengbrand
Participant
I have made an aggregation of lines that I have saved in MS SQL. when I then make a STGeometryType () on the table I find that a GeometryCollection has been formed. I want to avoid this and instead save it as a MultiLineString. However, I do not find any settings where I can control this. (then I will do the same for points and spaces to completely avoid GeometryCollection.)
Best answer by m_tengbrand
Now it's fixed, I had to run a deaggregate first, it was not the objects aggregated by fme that was the problem but the objects that were already multilines in SDE.
fmelizard
Forum|alt.badge.img+22
  • Dec 6, 2017 1:36 AM UTC
Hi @m_tengbrand, the GeometryCoercer might be useful in this situation. You can change the geometry if needed using this transformer. Additionally, I would suggest looking at what you have set to the "Collection Type Handling" on the Writer feature type (under Advanced)
m_tengbrand
Participant
  • Participant
  • Dec 7, 2017 8:31 AM UTC
