AutoCAD Layer to Excel
  • Apr 6, 2017 12:00 AM UTC
  • 7 replies
  • 195 views
Forum|alt.badge.img+3
I'm simply trying to write a summary list of the layers used in all dwgs in a folder to excel. The workbench will do this to inspector but not xls but I can't figure out what's going wrong, any hints?
  • Apr 6, 2017 2:42 AM UTC
Hi @just_super, to clarify the situation, could you please post a few screenshots that illustrate the followings?
  • How FME Data Inspector is displaying the summary list of the layers.
  • How you have configured User Attributes in the Excel writer feature type.
itay
Forum|alt.badge.img+19
  • Apr 6, 2017 5:06 AM UTC
You can try generating a workspace, this will automatically set all the attributes on the writer feature type.
After that you can remove any undesired output attributes.
To make sure a single feature per layer is written use a sampler transformer, set the group by to the layer and sampling on 1.
Hope this helps.
pratap
Forum|alt.badge.img+12
  • Apr 6, 2017 5:11 AM UTC
Scenario 1:
If the excel file is not generated then probably either file is opened or rights problem or configuration error.
Scenario 2:
If the excel file is generated without the layer names in excel file then you should add the attribute header in user attributes in excel writer.
  • Apr 6, 2017 1:17 PM UTC
Hope this helps.
Sound advice and kind of worked. The dwg is read and a xls written. However a sheet is being created for each feature type whereas I just wanted them listed. Just like in the log below!
gio
Forum|alt.badge.img+15
  • Apr 6, 2017 1:33 PM UTC
layer names are in autocad_layer and in fme_feature_type.
If u add the dwg reader to the canvas, the fme_feature_type is automatically exposed. (autocad_layer needs manual exposing).
Use a sampler grouped by fme_feature_type sample rate = 1 and sampling type = first n features.
Add writer and add the attribute to the excel writer (or copy it from reader).
There should be no problem.
(it will not write to open excel of course, but I assume you know that)
itay
  • Apr 6, 2017 1:46 PM UTC
easily solved by using a statistics calculator to do a count per layer and using the summery port.
  • Apr 7, 2017 11:29 AM UTC
Fantastic, thats working great.@gio
