AutoCAD Extended Entity Data not writing out correctly.
  • Feb 20, 2024 8:46 PM UTC
  • 135 views
gmbutler2
Forum|alt.badge.img+10
I am reading two AutoCAD files and sending them through a ChangeDetector to identify the differences between files.  For my updated features, I am trying to write out the attributes to my blocks to displayy the following attributes as extended entity data:
Id, Update_1,Update_2, Update_3 (all the way through Update_10)
Writer Feature Type Showing all the attributes.
However, when I open the drawing, the Extended Entity Data is being written as such:
Block Extended Entity Data is repeated, missed, and “garbled”.
Can someone give me some advice as to why this may be happening?
itsmatt
Forum|alt.badge.img+48
  • Feb 21, 2024 9:03 AM UTC
What does the data look like in the data inspector there and what version of FME are you working with?
certainly looks pretty strange
gmbutler2
  • Feb 21, 2024 12:11 PM UTC
@virtualcitymatt I’ll attach a few screenshots.
Here you can see the 2 items in question that have attributes.  Update 4-10 are supposed to be “missing” or nulls.  These items had 3 of 10 potential changes.  So 4-10 were empty.
Here you can see the first page of my writer feature type.  The Layer_Name attribute has what the level is supposed to be named in it.  In this case the Layer_Name is “CHANGE Update”.
Here you can see the attributes as they should appear.
Here is a refresh from the initial post of how they end up being written.
Here is a screenshot of my Writer Parameters
Here is a screenshot of my reader parameters (1 of 2)
Here is the remainder of my reader parameters (2 of 2)
