Autocad blocks from multipatch shape file
  • April 13, 2015
  • 14 views
Hello,
I am trying to convert a multipatch shape file to a DXF creating a block for each feature using one of the attributes as the block name. It seems that the DWGstyler only works for points. How can i proceed using 3d geometry?
Thanks in advance for your help.
Giuseppe
Best answer by pratap
To create the blocks in autocad 2 FME attributes are requird along with coordinates along with template file with block defined...
1. autocad_block_name = (Block Name)
2. autocad_entity = autocad_insert (Constant)
Change your attribute names as required. Hope this works...
Pratap
pratap
Forum|alt.badge.img+11
  • April 14, 2015
Pratap
