AutoCAD 3D file adding extra lines in surface
  • Mar 5, 2020 8:54 PM UTC
  • 54 views
When I bring in a 3D DWG file to make some bulk edits, FME is adding a lot of extra lines in the surface of the structures, triangulating vertices etc, these remain in a .dwg export. Is there away to clean this up so it presents correctly inside AutoCAD.
Original
FME DWG export
Many Thanks
Hi @gisjoshuareynol, thank you for your question. Would it be possible for you to provide a sample .dwg file so we can take a closer look at it? Thanks!
