AttributeKeeper does not keep coordinates
  • Jun 27, 2016 2:10 PM UTC
  • 61 views
I'm try to establish an SHP-Minecraft translation, but in the 2016 version of FME, I had some trouble with the AttributeKeeper. I have an input SHP (point), connected with a coordinate extractor. After that, I attached an AttributeKeeper. I want to keep some SHP attributes, and the coordinates, extracted by the CoordinateExtractor. For some reason, the Keeper lost the XYZ coordinates. If I took try the same in FME 2015, the keeper will keep the attributes. Is it a version error, or I missed something?
The following pictures shows the connection, and the settings. In the keeper, I cannot tick the mother attribute, just the children attributes (XYZ).
Thanks for your help.
Bálint
Forum|alt.badge.img+5
Hi @gulkhanra
Because the x/y/z are being extracted as a 'list' type of attribute, instead of using the Attributes to Keep parameter, you should use the Lists to Keep parameter, like so:
Hope this helps
Mark
  • Jun 28, 2016 12:23 AM UTC
Hi @gulkhanra, alternatively you can use the 'Specify Coordinate' option for the 'Mode' parameter. The transformer with this mode is equivalent to the one in FME 2015 and earlier.
  • Jun 28, 2016 12:31 AM UTC
In addition, it might be better if the AttributeKeeper could be improved to expose list elements which the user specify in the 'Attributes to Keep' parameter.
  • Jun 29, 2016 2:21 PM UTC
Thank you guys:)
I tried both, and both is good, but I prefered the AttributeKeeper version:)
I' can proceed now with my research:)
Thanks again:)
