After the translation failed message, I come to know whether source data is not as per the writer i.e. 12kV in source (present as type text) but writer accepts only 12 since it is integer...
Is there a way to check this type errors before, such that I can disable the writer and run the check. I will switch ON the writers when the data is correct.
Pratap
