ArcSDE write Domain value
  • November 11, 2013
  • 32 views
sigtill
Forum|alt.badge.img+24
How to set Subtypes and Domains are written here: However how do I read the allowed subtypes from a feature? Ie for the "Diameter" attribute I want to extract the value:text pairs of choices (0:Unknown,12:12",2:2" etc...) Schemareader does not work as far as I have seen.
http://fmepedia.safe.com/articles/How_To/Working-with-Geodatabase-Subtypes-and-
Domains
fmelizard
Forum|alt.badge.img+19
  • November 11, 2013
I think your out of luck with this for sde see http://fmepedia.safe.com/articles/How_To/Comparison-of-FME-readers-and-writers-for-SDE-and-Geodatabase
sigtill
  • November 11, 2013
Sorry, was unclear. Using the
Esri Geodatabase (ArcSDE GEodatabase) which according to that page will:
  • Supports subtypes and domains.
I can set up the readers to read domains correctly, and they are also defined on the writer - however I want to Map values from inputdata to valid domain-values using a SchemaMapper or AttributeMapper.
