Amazon S3 downloader does not work while first run and succeed only while the second run
  • May 9, 2019 12:26 PM UTC
  • 5 replies
  • 90 views
I'm working with FMEServer.
I developed a small workbench that connects to s3, reads the content of some folder and downloads it into FME resource folder. The problem with downloading occurs only while first running. I get the following error:
FAILURE
java.lang.Exception: COM.safe.fmewebservices.FMEWebServiceException: COM.safe.fmeserver.api.FMEServerException: QSInvalidRequest
When I repeat a job, right after that, the job is done successfully.
In both cases, engines are turned on.
My workflow is as follows:
Any idea of solving this problem?
Forum|alt.badge.img+63
You say "engines", so that implies there's more than one. Did these jobs run on different engines and if so, could there be a difference between them?
  • May 9, 2019 2:08 PM UTC
I'm not aware of the engines state. I use the default set that FME allocates to me. I turn them on with FME GUI Engines & Licences section. S3 downloader is the only workbench that fails with the first run. Others do well.
HI @przegee,
Which versions of FME are your using (Desktop & Server). In general, I would recommend using the S3Connector instead of the legacy transformers if possible:
https://hub.safe.com/publishers/safe/packages/s3connector
  • May 10, 2019 3:31 PM UTC
I use FME Server 2018.1.2.0 and FME Desktop 2018.1.2.0.
It looks like s3conector is not recommended anymore in my version.
https://knowledge.safe.com/questions/72013/s3-connector-what-happened.html
Have you tested it in the 2019 version?
Yes, it is released in 2019.0 and the recommended transformer to interact with S3
