AIXM 5 geometry with XML-Templater
  • Oct 14, 2024 1:18 PM UTC
  • 99 views
youssef
Hello Guys,
i have an issue with bringing our geometry from a oracle 12C format in a AIXM gml format. Whatever i tried so far, the writer just refuses to write any geometry, while anything else seems to work just fine. The output was good enough to satisfy the AIXM validation but it is useless for us until i am able to write the geometry too.
I am trieing to achieve that with the help from the XML-Templator and so far, this is how it looks:
It looks fine to me, the coordinates are hard coded for testing and will later be replaced by a variable holding the coordinates for each object. But i would like to write any geometry in the first place before i think about that.
I will provide my workspace and the gml i managed to generate with the hope that somebody can make out the issue at hand. Ty for reading this and every bit of help is appreciated!
nielsgerrits
Forum|alt.badge.img+67
I really do not know anything about this format and applications. I have no source data to try your workspace so it is very hard to reproduce. Maybe share a sample of your source data in FFS so we can reproduce and rerun your workspace.
Found some sample workspaces in the Knowledge Base (https://support.safe.com/hc/en-us) like this one:
https://support.safe.com/hc/en-us/articles/25407686750477-AIXM-4-5-and-5-1-Reading-Writing-and-Validation-EU-Airports-Demo
What I would do is use the sample workspace and modify it to your needs. You can find the downloads on the bottom right of the page.
