Adobe Geospatial PDF writer cann't output some text
endest
I cann't use the Adobe Geospatial PDF writer to output Chinese or Japanese text.
I have tried modify my font file's name and it's name show in FME's font window to non-Chinese;
also flow the help's instruction to modify the fme_text_string to rich format, like "你好", and set the parameter of Writer "Text in Rich Text Format" to yes.
But both failed.
If you can output some special non-English characters to PDF?
Thanks
Best answer by takashi
Currently the PDFStyler and the PDF writer (and some other transformers treating fonts) do not support non-standard fonts in Windows English edition. I reported it to Safe support a few months ago, they have acknowledged it's an outstanding issue on FME internationalization.
I strongly hope that it will be resolved in the near future.
Takashi
Forum|alt.badge.img+19
  • July 8, 2015
Takashi
endest
  • July 8, 2015
Hi Takashi,
I could use the TextStroke to deal with Chinese if I modify the font's filename and the really font name to english. I thought it's same with PDF. I was wrong.
Thank you.
bjarne
Forum|alt.badge.img+5
  • September 13, 2015
have you  tried this: <body><p style="font-family: Times New Roman">This is a font.</p></body> ?
endest
  • September 14, 2015
Hi Bjarne,
It doesn't work.
bjarne
  • September 15, 2015
Hi Endest,
I had a similar problem, but iit worked for me this way:
  1. Adobe Geospatial PDF, Writer "Text in Rich Text Format" to yes.
  2. Put the font in the same folder as the workspace.
  3. creator, text, coordinates 0,0:
  4. The font is embedded to the pdf, and text is written correctly.
endest
  • September 16, 2015
Hi Bjarne,
I do as your way with FME 2015 Build 15530 x86, but faild to output Chinese text string.
I wanna know which language you test and which FME edtion you use?
Thanks
  • May 29, 2017
I´om encountering the same problem with the latest release (build 17494). Could somebody please verify that it´s still an open issue? I´m using the fonttype "4000" (providede by one of our graphic designers) and it should be compatible with windows. Still FME (PDFwriter) won´t allow me to use the font (actually it wont allow me to use any font...)
Best regards,
Christian
