Adding a point cloud on top of another point cloud
  • Aug 19, 2016 2:53 PM UTC
  • 108 views
Hi
I want to add a point cloud on top of another point cloud (in Z) but I can't figure out a good way to do it.
I got a big point cloud (over 7,000,000,000 points) of a city and then I got a point cloud with a lot of pillars I want to place on roofs in the city point cloud. The pillar point cloud is aligned in X and Y but the Z value is way off so the pillars ends up inside or under the roofs.
Is there any way to read the roofs Z value and then set the pillars Z value to the specific roof Z, or is there a better way to solve this?
Thanks
Philip
Best answer by fmelizard
First blush -- PointCloudMerger might be able to do this nicely. So long as the X/Y values are the same in both point clouds, or you are okay with rounding the X/Y values (via PointCloudExpressionEvaluator) to make them "the same" -- once they are, then you can do tricks with the merger to transfer values from one cloud to another.
fmelizard
Forum|alt.badge.img+22
  • Aug 21, 2016 5:25 AM UTC
  • Aug 22, 2016 2:05 PM UTC
Yes, I managed to isolate the correct points with the PointCloudMerger and sorted out the points with correct Z value and added it to the pillars. It works now.
Thank you!
Philip
fmelizard
  • Aug 22, 2016 11:29 PM UTC
Thank you!
Philip
Great to hear. PointCloudMerger, according to @dmitribagh, is often underestimated in terms of its amazing performance, power, and applicability. A true undersung hero in the FME transformer choir.
